Toilet Flush Replacement (UK)
9 Sep 2012
Cardiff
Hello all, im new here.
The toilet in my flat has ceased working. I know the part that needs to be replaced but I am not sure exactly of the part name etc. I have been advised there are lots of different versions.
As you can guess im just a regular homeowner with not much knowledge about this sort of thing. I would be very grateful if someone can inform me of the name of the item I need to replace and whether a novice like me is capable of replacing it myself (it looks easy enough)
I have attached photos here...
//www.diynot.com/network/Phildo/albums/13455
Many thanks in advance[/b]
Looks like an MFI concealed cistern. If so any standard flush valve should fit but you make have to take the WC bowl out and remove the two front panels to fit the new one.
Thanks for your replies. Is it something I should call the plumber in for?
Have been given quotes of £60-£75.
Thanks again
