Toilet flushing problem
24 Jun 2013
Hertfordshire
In recent weeks it is becoming a frequent problem that on flushing the toilet is not getting rid of "solids" on the first flush, 1 in 3 times you need to flush twice.
I have checked that the water level in the cistern is at the correct level, there are no leakages around the siphon and although we live in a hard water area, the bowl is free of lime scale.
Anyone any ideas?
Get rid of the syphon, fit a Fluidmaster flapper valve.
Adjust properly. It is dual flush, so short for yellow, long for brown.
I have a fairly new pan (4years old) with the flapper finely tuned and normal number twos go away with the short flush of around 3 litres. Big bigjobs need a bit more.
Your problem may also be a blocked water ways around the rim of the pan, get a mirror and check for any blockages of ports or tiny holes from where the water streams out from, under the rim, the sides have smaller stream and the front and back have stronger streams or water flow to flush your bits you deposit !:LOL:
I know this from experience. I have cleared a few pans using a wire hanger to clear out!
Oh I should have added if by replacing the torn diaphragm in the cistern does not make any difference then check the pan water ways.
