Toilet installation - 2.5 inch outlet
3 Jul 2010
Warwickshire
Hello there
I am in the process of installing a new close coupled toilet in the bathroom. The toilet is from B&Q (not sure of the exact model) and the water outlet between the cistern and the pan is 2.5 inches in diameter.
All of the toilet flush valves on the market state they are suitable for 1.5 - 2 inch outlets.
I am looking at getting this one from screwfix...
http://www.screwfix.com/p/fluidmaster-button-cable-dual-flush-bottom-inlet/58353
Will this fit my toilet? I would have thought a B&Q toilet would be pretty standard and that most flushes would fit??
Also, i am trying to find a rubber doughnut / washer / gasket when fitting the cistern to the pan. Will i need a larger gasket given it is a 2.5" outlet?
Thanks for your help in advance.
if it's a new pan & cistern it will come with all the stuff why are you buying more ?
You see these toilets at the end of the check outs, being called a 'B & Q special'............................................... because all the bits are missing.
:LOL: :LOL: :LOL: :LOL: :LOL:
Andy
How did you get this sorted in the end?
I have exactly the same issue a toilet with 2.5 inch hole did the fluidmaster fit or did you get something else?
