Hey guys,
I found that our toilet keeps filling as there is a constant trickle of water from the top of the pan to the pool of water at the bottom. The toilet is the type with a push button flush at the top and a central 'drop valve' type siphon to release the water. When you press the button, a cable pulls the centre part upwards thus releasing the water.
I'm assuming that the sealing rubber ring on the bottom of it this has failed allowing a slow but steady trickle of water to pass through, hence why the tiolet keeps filling. The tiolet was fitted by the previos owner, and so I don't know what make it is, so how would I go about getting a replacment seal? If I removed the unit from the tiolet and took it a to a plumbers merchant, are they likely to stock replacements for these? Or would b&q have them?
