Hi all
I have a small leak, which as recently got a little worse, and I think it's coming from the bottom of the toilet pan, that connects to the outlet pipe/tube.
I have bought an extendable pan connector from B&Q.
I don't think there will be a problem with trying to fit the connector to the pan of the toilet, I know about turning off water supply, drain cistern etc... but how do you make the connection at the other end, because it just seems to go straight into the wall, and there's no obvious way of disconnecting it. Do you just pull it out?
Thanks for any advice you can give
Dirk
Dirk
