Hi All,
My toilet is leaking when its flushed - there are drips at this point here.
I thought it must be related to where the flush valve meets the cistern / basin. However the flush valve can be removed from the cistern so I removed it and turned the water back on so it was constantly flowing from the cistern down to the toilet and it didn't leak?. I put the flush valve back, let it fill up and flushed and it started leaking again! Any ideas?
I was going to take the cistern off but the nuts are jammed tight so hoping WD40 will do its magic.
