toilet overflow leak - wet chipboard flooring
7 Jan 2009
Nottinghamshire
i have discovered a small leak from the toilet cistern overflow which has dripped behind the loo for some time and so has wet the chipboard flooring around it.
any tips on how to dry out the chipboard and to identify whether i need to replace the chipboard?
if i have to replace it, it means the toilet coming out etc so i would rather not if its not necessary.
A fan heater will dry the chipboard. The only way of testing whether it is sound or not is to poke it firmly in several areas with a screwdriver.
You may be lucky, but I suspect not :cry: :cry:
right, i have lifted the lino from the floor , the wet area is about 2m square, but it is soaking wet just around the toilet itself. i have jabbed it with a screwdriver very hard and it does not give way at all, even in the really wet parts. i have put blocks of wood to keep the lino spaced from the boards to allow it to dry out.
i may have been lucky this time!
