Toilet pan connector
17 Feb 2010
Argyll
I'm trying to install a new toilet (not done one before) and have got a McAlpine (MAC-1) 110mm straight pan connector. When I push this on to the back of the toilet should it just stay in place? Looks like the outlet on the pan is tapered slightly and the connector just pops off no matter how far I push it on. Once installed and the pan is bolted to the floor the waste pipe will probably keep it in place but I have no idea if this is normal and if it's going to leak. Would really appreciate any advice on this.
Thanks.
Not really, the pan spigot wouldn't normally be tapered, it would normally be straight sided.
That being said if you can get it to stay in place and watertight with the pan in situ then that may be all you can achieve.
Hey tireetim.
I'd suggest you first measure the maximum depth the pan connector has available, then mark using a chalk/watermarker on the toilet outlet.
That way you'll know how much of the connector has actually been pushed on.
It should have a snug fit feel to it as you completely push it on.
Good luck. :)
Thanks Madrab and Crystalclear. I've just taken everything apart and had a closer look. It seems that a drip of the ceramic coating stuff on the bottom of the spigot was catching the inner seal on the connector and stopping it going on properly. Pushed it over and now it fit's fine and looks like a good seal. Cheers.
