I am fitting a new toilet and am planning to move it over to the left approx 5 inches to make room for a boiler.
I am plannind to use Multikwik flexible connector to get the correct angle, but it then needs to go into a 8cm diameter lead pipe which is fixed into a cast iron pipe outside of the house. What connector will I need to change the diameter from the flexible connectoer 97-108 down to the 8cm? Also how do I seal it into the pipe? Shall I use silicon sealer around the top of the lead pipe, to prevent leaking?
Thanks, any help is appreciated.
