Hello,
I'm installing a ground floor toilet soil pipe into a new extension I'm having built and had a few queries that i'd be very grateful for any advice about, before the pipe work is concealed under a concrete floor!
At the moment I have the 110mm soil pipe running from out side the new extension wall where I will connect it up to a nearby inspection chamber at a later date to an equall T the upright will connect directly to the toilet outlet through the floor with a length of 110mm pipe the other opening continues a further 300mm to a 90degree elbow which will come up through the floor and be fitted with an internal air admittance valve for the sub stack.
I'm wondering if there is anything wrong with this set up? and secondly I have set up all the pipe work so that it has half a bubble of fall on it using my spirit level so I'm wondering if that's enough fall or not? If the toilet soil and sub stack are ok I will also be connecting the sink waste into the sub stack.
any advice or thoughts would be greatly appreciated.
Many thanks
John
Many thanks
John
