- Joined
- 22 Oct 2007
- Messages
- 130
- Reaction score
- 0
- Country
[Subject Edited Tues 25th 17:30...need a pan connector to fit into a 130mm approx non standard soil pipe. Thanks for any help ]
I've done a search for this but can't find much info so here goes...
I'm replacing an old toilet that has what I presume is a S trap, the soil pipe exits through the floor under the pan.
1st Question:
The soil pipe seems to be too far from the wall for the modern horizontal (P trap?) toilets...the centre of the soil pipe is approx 260mm from the wall. can anyone confirm my suspicions?
What are my options? The bathroom is on the ground floor and the soil pipe comes up through solid concrete. All I can think of at the moment is boxing out from the wall to meet the back of the new pan/cistern with backing board which would leave me with a shelf behind the toilet.
2nd Question:
The soil pipe is about 140mm in diameter, and seems to be thin black plastic, wall thickness of 2 or 3mm. It projects from the floor by about 30mm. The S trap of the toilet is sunk into this and seems to be sealed in with cement or some type of putty. Firstly, any idea if the black plastic thing itself will be some sort of adaptor to make the pan fit the soil pipe, or is it likely to be the pipe itself.
Secondly, is there a connector that will connect my pan to this pipe? I assume it would just be a push fit with rubber seal rather than the cement or whatever it is that seals the existing connection?!
Thanks for any help
1st Question:
2nd Question:
Thanks for any help
