Toilet sounds like water running
29 Dec 2018
Hi, I have moved into a house recently.
It sounds like in one of the toilets, the water is running or tricklingm it's a built in flush.
There's no movement in the water if the toilet to indicate there's running water in there itself so I'm not entirely sure what it is or if it's anything to worry about
Any movement on the water meter, ten minutes after last water use? After an hour?
Does the cistern have an external overflow pipe?
Hi, no it doesn't. It's one of 3 toilets and it's the only one that does it. But it's not constant, like now it's making no noise at all, other times as I say it sounds like a trickle of water
Semi detached house if that could make any difference at all
Hadn't even thought about that,to be honest it's hard to know when to look, now it's quiet and making no noises other times as i say it's like a constant trickle sound
Float could be compromised mean slow filling or flush not reseting as quickly as it should .
