I am fitting a new toilet and pre installed the waste pipe through a 50cm stone wall. I set a small drop off from inside to outside and then sealed the gap around the pipe with cement. Unfortunately it seems to have dropped on the inside before it set and is pretty much level now (if not a very tiny rise) for about 50cm. Will this be a problem as it's going to be a nightmare to cut it all out and start again (walls inside tiled etc.)
Also, does anyone know the correct drop for this pipe?
Thanks.
Thanks.
