I'm putting together some sketches ready to get quotes from some builders in order to have a dormer built to house an en-suite.
I'm trying to envisage any issues before hand.
Luckily there is a toilet below the area that we want to put the en-suite so I'm hoping that they will be able to somehow tap into the pipework below.
My only worry was the main toilet waste pipe. The current toilet downstairs has a pipe which goes out of the back of the toilet and then turns 90* to the left, then has a short straight section, then another 90* bend to the left, then a very short straight section (virtually nothing) then another 90* bend down into the ground. This slightly complex arrangement comes from moving the toilet a few years back. The easiest place to join into would be the short section after the first 90* bend. My worry is that if you then used the flush upstairs, it would basically go straight out of the toilet, then it would have a 3m drop and hit the pipe at the bottom only a few inches from the toilet downstairs - would the force of it falling send it into the other toilet?
If it is a problem I would need to get it dug up outside and a vertical pipe up the outside, but as it is a dormer that would need to be at the side of the house which would mean a bit more digging up to connect it to the sewer.
Also if the interior option would work, would I need a vent on the top? If so am I right in thinking that there are solutions now that give you a vent inside rather than having to go through the roof?
