Hi
Can anyone throw any light on this problem.
We have two downstairs toilets, which were working perfectly OK.
About a month ago my son was using a digger in the front garden and
came across a manhole cover that we didn't know was there.
(We have had the drains cleared before by two other exposed manhole covers).
He found that a lot of ivy had got at the side of the cover, he removed it and
then the manhole cover, and said that he could see that the sewer was running OK.
In the last week or so, both toilets have been filing nearly up to the under the rim.
And were very slow to drain away.
There is obviously a blockage, which might be my fault because I have been throwing
paper kitchen towels in the toilet every now and again.
I only found out the other day that you shouldn't do this because they don't breakdown.
Over the last few days I have repeatedly poured buckets of water from as high as I
could get, it to increase the pressure.
Today, it finally improved in as much as the water is now about 2 inches from the rim,
and leaving the bowl quickly.
SYMPTOMS
When either of the toilets are flushed, the other gurgles - when you unplug the bathroom
basin the toilet bowel rises.
Given that the sewer a month ago was running free, where do you think the blockage will be?
The en-suite toilet runs under ground with around one metre before it reaches the
manhole/sewer run. There is no exposed soil pipe.
(There is a soil pipe for the upstairs toilet - vented etc.)
The bathroom toilet is connected to the en-suite toilet - i.e. they both exit the same way on
the same run.
I was thinking of ordering a "flat" rubber disc on a wooden handle to push down into the bowl
(seen one on the net) but wouldn't the pressure just force the water out of the other toilet?
I know I can blocked the basin overflow with a cloth - but the toilet?
Any help or other suggestions would be appreciated, .
Thanks in advance.
Stephen
SYMPTOMS
the same run.
Thanks in advance.
Stephen
