Water from taps is scalding. There is a thermostat in the airing cupboard beside the hot tank and one on our new boiler. Which do I use to turn water heating down?
If your hot water temperature is greater than the 65c set on the stat ,the stat may be faulty . Do you have an electric immersion heater also ? If so, ensure it is switched off.( Just to rule it out of the equation)
