Too hot
25 Nov 2008
Kent
Hi , my Room stat wont switch off .It clicks but the neon light stays on and so does the boiler getting hotter .Only cure is to switch mains off/on.Changed room stat.This happens now and again.
Any suggestions ??????
Boiler
3 way valve
Cylinder and stat
room stat
pump
programmer
It is likely your mid-position valve is stuck, see if you can see what manufacturer it is, i'm guessing potterton or llandis & gyr, depending on that, try taking the head off valve and see if motor goes back.
Thanks , yes I thought the valve , just couldnt see how the led stays on the room stat.It must somehow put a live feed back on the thermostat from the valve.
