We've got some rads in our heating system that are not working correctly.
The property has 4 levels including the cellar.
There are 15 rads in total. Over the years I've upgraded 11 of them, bigger in size or single to double.
Two rads don't heat up fully, one is large @ 40cm x 300cm, the other is average size and in the cellar.
The pump is a Grundfos Selectric 15/60 we run it at 2 and all but 2 rads are working fine. Setting it to 3 does not heat up the two rads mentioned above.
Boiler is a small, old Potterton suprima which needs replacing when it dies.
The system has been cleaned and drained, no air in the system.
Do you think I need a bigger pump? Any suggestions?
Sent from my iPad
Sent from my iPad
