If you take your hands and spread your fingers apart slightly you can then interleave them. I'm wondering if there is a tool that is maybe like a series of X mm saw blades, mounted X mm apart that one can use to cut fingers into the end of the stud, the idea being that two studs could then be dipped in glue and the fingers knocked together.
Kinda like multiple small mortise&tenon joints, but with the aim of making one long piece of wood rather than a corner
The query comes about from looking at the engineered I joists I have.. the flange seems to be formed into a continuous run from multiple short lengths, every now and then the flange exhibits a triangular wiggly line where an interlocking triangle pattern was cut into the ends of two bits of wood, then they were glued together. Of course, the same happens with the osb web and the other flange but never in the same location as any other joint. I have hundreds of offcuts of timber, all a bit short for the purpose I need, but if I could joint them reliably..
