I have fitted a new mixer tap to my bath a month or so ago and recently the hot water tap has started to slow and to the point that I get a few litres of hot water into the bath and then barely a dribble.
I cant access under the bath due to the bath being boxed in.
I think the problem is with the tap (not water pressure or anything) but I cant get to the nut to take the tap off. There is a 'skirt' - for want of a better word - around the tap which unscrews and lifts up a little, but I cant take it off entirely because it wont lift over the tap handles. However it does lift up about a centimetre to reveal the nut underneath but there is only a few mm at most of access, so I cant fit even my smallest wrench around the nut.
Is there a special tap tool (spanner?) that I need to use to get the tap off? I've had a look at all the spanners in my local DIY shops and they are all to chunky to be able to fit into the gap.
Any advice much appreciated.
Tom
Tom
