R
RedHerring
I’ve just completed my first rendering job and I had a bit of a problem with the topcoat so I’d appreciate opinions &/or advice.
The wall is concrete block and the scratch coat went on with no problems whatsoever. I used 10mm battens and a darby to help with an even coat. (Something which I learned but have not seen advised anywhere is to run a trowel along the sides of the battens after scratching this first coat. It makes it much easier to release the battens the following day) I used a mix of 1 cement, 1 lime and 4 plastering sand for this scratch coat. Due to my amateurish speed it was between 4 to 6 days before I started the topcoat. No PVA has been used at any time, allthough I was going to prime it before painting with a spray of diluted PVA.
The problem was experienced with the topcoat. I'm talking probably about a total of 1.5 sq metres in 5 patches in a wall of about 20 sq metres. I did soak the scratch coat really well before starting the topcoat and occasionally during. Occasionally the topcoat would not adhere too well to the scratch coat and bits fell off, not on the initial application but later when I was wooden floating it to get a relative smooth finish. I used a 1 cement, 1 lime, 5 plastering sand mix for the topcoat, aiming for about a 5 mm thickness.
Did I polish the scratch coat too much before scratching it? Was the scratch coat mix too strong? Did I use too much sprayed water while floating it with the wooden float? Did I leave it too long before applying the topcoat?
I have to patch the bare bits today. I cleaned the patches yesterday where the bits fell off and wire brushed the scratch coat to make sure there’s a good key.
Another question I have is about the corner angle, stop beads and bell casts,
I used the corner angles, stop beads and bell casts (all stainless) under the scratch coat but it seems to me that the corner angles and stop beads might be better utilised on top of the scratch coat. Whereas the bell cast worked well under the scratch coat. Advice would be appreciated.
