Hello. Thanks for looking at this post.
My central heating system is to be extended into a basement. Part of the existing central heating already services a ground floor room above the basement. The obvious method of extending the central heating system to the basement will be to link into the pipes under the floor of the ground floor room and bring them down through the basement ceiling.
To minimise lengths of pipework, I'd like to install a modern vertical radiator which has fittings for inlet / outlet at the top and possibly a thermostatic valve somewhere a bit lower for easy access.
Is there a vertical radiator available, or other type of radiator, which has top side inlet / outlet?
