Topaz Electric Shower
20 Apr 2014
I have a Topaz electric shower which will only dispense cold water. It also pours water out once you pull the cord whether or not it is turned on. Any ideas before I rip it out and replace it please?
two main components in an electric shower. one heats the water, the other one is a valve.
Valve is supposed to operate only when the shower is switched on, and the heater should only work when the water is running.
sounds like the control circuits have died so I'd consider a new one if you can't fault find
