I have installed a bottom entry Torbeck valve to fix the previous and now defunct brand. After flushing the water level settles but then quiet often there is a dull humming sound that only ceases if I readjust the float. But often the dull sound starts again and I have to repeat the process. I have tried swopping the high pressure comb to the low pressure and also removing it completely without success.
I also have turned off the water, run all the taps, and then refilled the cistern, but that has only served to cause some of the taps to splutter out water occassionally.
I'm pretty sure it is mains fed (but I am basic DIYer).
Sometimes if I put pressure to one side of the main body the hum will stop, but releasing it will cause the hum to start again.
Is the hum water hammer or a sympton of it?
It sounds similar to this previous thread, which suggests a leak?
//www.diynot.com/forums/viewtopic.php?t=51855&view=next
