I,m having an issue fitting a new Torbeck valve (bottom feed) to a cistern.
Before filling I decided to turn the service valve on , hold the float up ,ie in closed position to see if it worked......water flowed unhindered wether the float arm was up or down......am I missing the point here? will it work (close off the supply)with water up to the correct level in the cistern or is the valve faulty??
Thanks for your time. ,
