Can anyone recommend a good torque wrench for occasional use? The most immediate job is to tighten the nuts on a towbar to 134 NM.
Also, regarding the size, most specs state half-inch or three-eighths inch. Does this refer to the fitting width on the rear of each socket? If so should this be measured from corner to corner or side-to-side of the rear recess of a socket?
Thanks in advance.
Thanks in advance.
