Touch latches with butt hinges
9 May 2014
Dorset
Subject sounds like the start of some terrible '70s joke.
But anyway ... just wondering ... want to build cabinet doors with no handles that use touch latches to open (eg. you push the door in 2-3mm and then the door springs out). And I'd like to use butt hinges for these, as it is in a room which I don't want to become too 'kitcheny' with those big metal 'concealed' hinges ... but what would be the best way of doing this?
Think I will need to set the butt hinge off at a slight angle, so as to allow the door to be able to push in that little bit ... is this easily done do you think? Are there any particular butt hinges that allow a little travel beyond 90 degrees?
Am fairly proficient now with the old woodwork, but was hoping there might be a quick hint from one you kind people ... thanks!
Should be enough play with hinge to operate touch latch, the lay on hinge might be a good choice.
Sorry ... what do you mean by lay on hinge? Was hoping to use the old-school bog-standard butt hinge .. ie. all you see from the outside of the cabinet are two barrels top and bottom of the door ...
Google Screwfix, type in butterfly hinge I think that isvcwhat Foxhole is referring to as aan alternative, but a butt hinge will work and work even better if you put a leading edge on hinge side and closing edge
