I'm after a filler for a plaster wall that will fill to a depth of approx 50mm, and will set and bind strong enough to screw a load bearing bracket into (curtain pole). There's no other place to fix the bracket, and the areas been filled and refiled so many times there's just no strength in the wall in that area anymore.
Any ideas, i was thinking of some kind of epoxy filler prehaps???
Cheers!
Cheers!
