hi everyone,
Reclaimed solid wooden flooring boards - very dark in apperance and scratched however hides a beautiful mahogany wood / patina underneath. Problem.....the manufacturers 'baked on' Varnish and possibly one other coat on top of that too.
Must remove this - have tried the following:
Sanding (all grit types) - powdered varnish cloggs up paper. Tried very course paper but sanding circles are a mission to remove.
Nitromors and other paint/varnish stripper - removes something but not much, ill be at it for months otherwise.
Turps - same as above
Thicknesser (running @ 0.5mm)- fine untill you reach a knot in the wood, then rips chunks out.
So...i need a cost effective way of taking this nuclear rated varnish off. Would prefer an acidic solution to use like paint stripper but with better capability than nitromors...any other solution...??
all replys much appreciated. I getting cheesed at this cos i know this should not be a difficult thing to do...
thanks
imster
[/b]
thanks
imster
[/b]
