Towel Radiator alternative
rcs
28 Jul 2006
Hi
Does anyone know of a towel radiator that gives off a decent amount of heat but will fit under a window? The size would be limited to 700mm high but length is upto about 1500mm. I'm still considering just putting a normal rad there as having a warm bathroom would be more important than warm towels.
Any advice appreciated.
rcs
Thanks for the reply but that's the point. I only have 700mm of height to play with. Not sure what the heat loss is but the room is only 4 sq mtrs with 2 insulated outside walls and a large window.
Cheers
rcs
Sorry mis read your post (hung over and trying to find a new mortgage simultaneously :().
Looks like you'll have to get a normal rad or buy a custom job.
Have you thought about old school rads?
I doubt you'll need much for that room.
Well I can put a 700Hx400W Towel Heater, but would that provide enough heat for the size of room?
Cheers
Hangover and mortgage research? Not a pleasant combo!!
PLUS nearly a months worth of paperwork!!!! aaarrghh
An I gotta clean the house for the wife's reuturn tomorrow 'cos the cleaners didn't turn up.
Anyway... why not fit one it its side? then you can get a bigger one? Get one that has evenly spaced bars otherwise it'll look obvious.
700X400 towel warmer, Phwoar, freeeezzing cold bathroom.
600X1200 Double, uhmmm, really really as warm as toaste :D
Well that's the way I'm thinking at the mo. Could always get a hanger for the towels over the rad (no airing cupboard). Might not look as good but come winter (and new born!!!!) I think I might regret not putting in a rad.
rcs said:
Hi
rcs
Put two or three side by side, by coupling the rails with chrome pipe and fittings. BES will supply the chrome fittings.
http://bes.co.uk
I did think of putting a few side by side, but even then, the output will still be quite low. I've seen some old fashioned type radiators that have a towel rail built in but they are of an old fashioned style. I would prefer something modern. Hole in the market or a niche?
Thanks for the reply.
rcs
rcs
Myson have a radiator with a towel rail attached to the front.
You can couple up a few and then put one on another wall as well if space.
Also look here:
http://www.mrcentralheating.com/towelrails.html
Or put in a Myson kickspace under the bath and a towel rail. This will heat the place up no problems. The under bath units have 12 volt electrics.
