Towel Radiator and Stud Wall
5 Jan 2006
Manchester
Hi all
Just wondering if anyone can help with this question. Currently in my small bathroom, there is a radiator right next to the toilet which i would like to remove and replace with an 1800mm towel radiator further away from the toilet.
The wall on this side of the bathroom is just a studded wall, i'm just wondering whether this will be strong enough to support such sized radiator? I could always reduce the size of the radiator however the wall it will be attached to is a recess behind where the door opens to so would be a good use of space.
Any advice or previous experience would be kindly welcomed
Kev
For standard rads on stud walls i use board fixings and sticks like s**t on the brackets although would'nt use this method on towel rads. could try using toggles ;)
