Hello all,
I've read all the the topics I can about this, but nothing seems to fit the bill.
1. Towel radiator runs off hot water system. It's worked fine ever since we moved in 18 months ago. It was changed 10 months ago because the old one burst (through age).
2. We turned it off during the summer (ie we turned the two valves at the bottom clockwise).
3. When we went to turn it on again in November, no heat, either in the radiator or in the two pipes feeding it from the floor.
4. I've bled it. A good squirt of water comes out.
5. I've turned up the pump in the airing cupboard to maximum, in case a bit of extra pressure might unblock something.
6. The only suspicious thing I can see is that the valves don't turn very far: probably half a turn at the most. Maybe my memory is playing tricks with me, but I think they used to turn more than that. But if it's the valves which have seized, why would I get such a good, pressurised squirt of water when I bleed it? Might this be because *one* of the valves has seized, i.e. the 'out' flow?
Any advice gratefully received. We're missing our warm ensuite...
