My sister has a small towel radiator that appears to be leaking slightly from one of the 'tails'. I removed the radiator, only to find that there is no obvious way to remove the tails, something I haven't seen before - instead of the usual large allen key-shaped hole there were just two small bumps on the inside. There was no obvious way internally or externally to apply force to remove them.
Do some radiators come with the tails pre-installed and not removable? Both the radiator and the tails are Tissino brand, so good quality. Thanks for any advice!
