Installing a circuit supplying 5 towel rails from a thermal store, circuit will have its own smart pump and timer, each towel rail will have a trv and a manual bypass will be fitted after pump, will this setup comply with part L ?
i know what part L means and complying with it doent require any special qualifications (fitting TRV's for example)
To be pedantic, that's not quite true. Non-notification (i.e. self-certification) of a gas appliance installation is permitted only when performed by a suitably approved person.bit of a non statement, as no building regs require special qualifications.i know what part L means and complying with it doent require any special qualifications (fitting TRV's for example)
I bet that if you get certification done by building inspection, and you have installed it yourself as a homeowner, they do not ask you for your qualificationsTo be pedantic, that's not quite true. Non-notification (i.e. self-certification) of a gas appliance installation is permitted only when performed by a suitably approved person.bit of a non statement, as no building regs require special qualifications.i know what part L means and complying with it doent require any special qualifications (fitting TRV's for example)
I don't see why anyone would want to bet against you, since you're gambling on the BCO simply doing what it says in the Building Regulations.I bet that if you get certification done by building inspection, and you have installed it yourself as a homeowner, they do not ask you for your qualifications
I agree, and so it seems that you don't deny that this statement was wrong:I don't see why I should offer a bet unless I know I am going to earn some dosh.
FFS, we've already done all of that.Am not aware of any building regs that require qualification, but by all means, enlighten me.
