Just moved into a new house and have cold a towel rail which I believe needs bleeding (top half is cold).
Only thing is I can't work out how to bleed it.
It's an old Myson rail and this is a pic of what I believe to be the bleed valve:
There's a circular piece of metal on the end which doesn't seem to move, but I didn't want to force it as I've got no idea which way to apply the pressure.
A second problem I've got is there's a leak from the lower left 'tap'
Can I just drain it then dismantle and PTFE the joints or is that unlikely to be enough?
Any help on either problem would be much appreciated!
Cheers,
Simon
Cheers,
Simon
