Hi all, spent the last few days remodelling and retiling downstairs WC and the mrs is keen for a towel radiator.
However the pipes are a little too close to the wall for it to be straightforward.
I’ve put it up for now, just using the two top brackets, but the rad is at an angle. It seems the closest it can be to the wall is 75mm using the supplied brackets, and I need it about 50mm.
The pipes can’t be moved, not without taking the kango to the concrete floor.
Are shorter, lower profile brackets available anywhere?
