Can anyone give the procedure for fitting a modern towell rail in a bathroom to an existing microbore system with one twin valve on the rad, the pipes come straight up from under the floor and into the twin valve. any help would be appreciated
8/10mm x15 reducer from each micro. pipe to a length of 15mm pipe and fittings as necessary to connect to each end of T/rail via rad valve ....t.r.v. not necessary
