Toyota Aygo Cd Problem
11 Nov 2012
Lancashire
I'm having problems with my factory CD player in my 07 Toyota Aygo. Can anyone explain to me why whilst im stationary the cd works mostly fine with the odd jump but as soon as i set off the cd jumps every second? Thanks
Try a lens cleaning disc. Normally, I wouldn't recommend the things, but you would need to get the unit out of the dash to clean it properly.
worth trying a laser clean but it sounds more like an issue with the vibration damping mechanism. Not sure if its something a car audio specialist can look at for you as the main dealer will probably suggest replacing it.
