tracing a short circuit
30 Oct 2006
Buckinghamshire
can anyone tell me how to trace the location of a short circuit in a radial socket outlet circuit using the insulation resistance test?
You can't actually trace it as such with an IR tester , all you can do is keep breaking the circuit down into halfs and testing to see which half contains the fault. (Well I suppose thats tracing, but then so is digging it up along its entire length to look for damage :confused: ) but if you want to have something which will actually trace the fault for you, then you'll want a TDR as opposed to an IR tester... now those really are magic! (at least unless you have dabbled in electronics a bit, then that kind of spoils the illusion a little :) )
P.S. Shouldn't you be asking your lecturer?
It can be found by measuring the resistance to short from both ends of the radial ( circuit is along wire to short, through the short and back along the other wire ) and using the diference to calculate the ratio of the resistances from both sides of the short. This ratio, assuming the same cable is used throughout will give a ratio of lengths either side of the short.
Hints
[1] the short circuit may have a resistance.
