I am trying to locate a fault with an outside 500W PIR security light.
There is one double wall point with twin dimmer switches, the left hand switch controls the internal light which works and the right hand switch controls the external light.
The wiring is as follows: left internal light is connected L1 -red and COM- red, on the other switch -external there is one red wire connected to the COM connection.
All other connections Black wire connected together, and all earth wires together into the metal wall casing.
I have tested the external light and there is no current getting to it at all,
also the one Red wire going into the wall point (connected to COM for the right hand switch shows no current.
So my question is - do I have a break or malfunction in the external lighting wire or are the connections in the wall point incorrect.
Any help appreciated
