I have a property with a piece of lead pipe which goes from the stopcock at the front right
through to somewhere at the rear.
At the front where the stopcock is the lead pipe is sitting on the ground under the suspended floor so it's route is easy to follow. Around half way though, it disappears under a concrete floor as it makes it way to the rear.
I'd like to trace this lead pipe as I am going to replace with plastic and my theory is that as I'll have to cut in to the concrete floor in order to put in a plastic pipe, I'd might as well use the channel created by removing the lead pipe.
So, how do you trace a lead pipe under concrete? Are there any special tools which I can hire or are there easier ways to do this. I recon it is approx 300mm deep looking at where it enters the concrete floor so I'm not sure a pipe detector would work!!
