Trade tips for removing seized valves from a radiator?
8 Jan 2009
Cheshire
I need to put some new valves in an old radiator and the old valves are seized in the radiator. I wondered what the trick is to get them out? Heat treatment with a blow torch (assuming the rad doesn't conduct the heat away), several wacks with a hammer? They are older valves that don't take the large hex key.
Many thanks in advance.
There are several different types of rad valve turning options and I would like to know what thread size and what turning option yours use. There are also different rads, pressed steel, aluminium, cast iron etc!
Most heating engineers can get most valves out but I cannot give you any detailed guidance without full details and ideally a photo.
Tony
some heat usually works, or try using a shifter on the allan key to give more leverage
try taking the valve off the pipe, refitting to the rad tail(very tight) then undoing the whole lot using the valve as the bit you unscrew with your grips, it'll bring the tail out with it a lot easier.
Use this method when my rad tail ratchet fails to do the job.
Thanks for the tip. Since I am going to get a new boiler installed and the corgi will charge a large amount, I figured he could struggle with replacing valves on 6 rads :)
Lee im surprised at you. :eek:
2 ball pein hammers.
Yes but he won't do it free.
£60/hr maybe. OK?
Do you mean that the tails are seized in the radiator?
If so, then leave them in - removal is a risk that isn't worth taking. Just fit valves that match the tails.
