Hi, I hope somebody can help here, and advise me on anyway I can persue this.
When I moved into the terraced House I'm currently in, built around 1888 I think, it had a number of problems I've been slowly dealing with. DIY where possible, but pulling in Tradesmen here and there when things were beyond my knowledge or skills.
A couple of years ago, I found a creeping rising samp below the window in my back room. I must have not noticed it for a long time, due to the TV and a chair mostly blocking the wall. But a loud cracking of the plaster made me notice that it was coming loose. Pulling off the wallpaper i found that the wall was completely damp, and all the plaster along the wall was about to fall off.
I called in a TRadesman who has done some other work for me, and he treated the rising damp with a kind of solution that is injected into the mortar instead of the bricks, which I've seem before. I had it replastered, and it cost me a lot of money, not to mention disruption.
In the time since I have entered the world of unemployment and poverty, and am uttery broke...
Now on a random check around the house the other day I found thick white mold growing on the wall just above the skirting board along the 'treated' wall. Cleaning it off, and toiching the wall, I found that it is still damp, albeit to a lesser extent, and so far just for about 10cm above the skirting board. it's ot risen all the way up the wall.
Obviously the treatment has not worked.
So I sent the tradesman the following email:
Hi ****,
I have a serious problem with that bit of damp treatment you did under the window in my back sitting room. It doesn;t seem to have been done properly, as the wall is damp to the touch, and I have just found mold growing on the walls, along the bottom. It's been hidden behind the chair, but I just found a really bad growth. This is very serious. I cannot afford for the plaster to come off again, the mold spores floating in the air, or damp to increase etc. Could you please come and do something to put this right asap before the plaster starts bulging and loosening.
Thanks,
to which I got the following reply:
Hi *****
It sounds as you might have a drain problem from out side, due to no cavity wall the bricks just sock up the water hence the mold. Unfortunately I don't work for myself anymore I sold up,the recession hit the building trade so I work for someone else now doing something complete different .
Regards ****
This doesn;t follow. The house is double skinned, how can there be no cavity? I'm pretty sure there is. Even if it is the case, the walls were treated, so if it is from a drain (there is one nearby but it's small), it still shouldn;t soak up past the protection. Otherwise what was the point of the treatment?
Further to this, he treated other parts of the house with the same stuff, so I'm concerned about the same thing happening there.
As he's said he no longer works self-employed as a builder, what are my rights? I cannot afford to have this all done again, and shouldnt have to either If I can. Can somebdy please advise me on this and where I can go? Thanks.
Hi ****,
Thanks,
Hi *****
Regards ****
