Hi, I have a Tranico oil fired boiler and a Megaflo system fitted in my house. The system started playing up a couple of weeks ago. When the timer cut in for the water to heat the boiler would start and stop a few times before running normally, just liken the boiler wasn't igniting. It is now not firing up at all so I turned down the room thermostat so the heating would cut in and the boiler is fine which makes me think the problem is in the airing cubard. The megaflo is fitted with an immersion heater which will heat the water fine when turned on. There are two wires out from the Megaflo, one goes into the immersion switch and one into a electrical box. Would it be a thermostat problem? If so are there 1 or 2 thermostats and where are they located and is it possable to test them. Im no electriction but know my way round the wiring and am a Auto mechanic so have an idea on the subject. Hope someone can point me in the right direction.
