Hi there,
I am tiling the dining room, using ceramic floor tiles over 12mm marine ply, screwed at 300mm centres. This is all on chipboard floating floor. Once it is finished the floor will be quite a bit higher than the adjoining rooms which have fitted carpet and underlay. (12mm ply, 6mm tiles plus adhesive layer)
Anyone got suggestions for door strips? At present there is a standard carpet to carpet strip which will have to come up. I have looked in all the big DIY stores and 12mm seems to be the biggest rise on a carpet to hard floor (designed for laminate really).
I suppose I could use regular wooden carpet gripper for the carpet side then cut a wooden strip between to screw a flat door strip to at a sloping angle, but I would have thought someone would have come up with a solution for this by now.
If anyone can suggest an alternative supplier or idea I would be most grateful.
