Transporting fridge/freezer.
23 Jul 2005
Dumfriesshire
I have to transport a fridge/freezer ( Bosch, about 5 years old ). It is too tall for my enclosed van. Is it OK to transport it on it's side or back ( all the pipes and fins on the back are protected) ? I'm not too sure so any advice would be welcome.
Thanks in advance. :)
yep will be ok. Just make sure you leave it vertical for a few hrs/overnight before plugging it in
If you look at the compressor there are three pipes, one short, one thick and one thin. If you lay the machine on it's side with the THIN tube uppermost, that is he delivery tube, then no oil will get into the system so you can plug it in as soon as you like when in position.
Colin
Sorry Colin 1 that isn't the case, you want to get the Thicker pipe (suction) uppermost as the oil cant go down the delivery (discharge) pipe as the oil won't get past the compressor valve reeds, but it will travel down the suction pipe and stay in the evaporator. If you lay any fridge on it's side or back go with ^neo^ advice
cheers
Thanks for all your help. It seems I should be OK but am a little confused about the conflict of advice in the last two posts. Anyone else like to offer anything?
Thanks again. :confused:
Thank you Racket, I bow to your superior knowledge, I have been doing it wrong for the last 36 years moving refrigeration units on the wrong side but thankfully have never had a problem (very lucky) I have always assumed any oil leaving the compressor in the suction line would not actually get into the evaporator as it would be higher than the compressor and when the compressor starts to run any oil in the suction line would get pulled back into the compressor, but any oil entering delivery line through weak, leaking valves would get pushed into the evaporator causing a restriction.
Ps. I've been informing hundreds of people incorrectly as well, thankfully haven't had anyone come back to complain of a problem.(very very lucky)
Colin
Sorry Dorset, your a long way from Dorset, our posts crossed as you can see from times.
It would always be best practice to allow unit to stand to allow any oil to drain into the compressor, but the rest is said in my previous reply, I have never had a restriction through my moving a unit and other that small units they have all been moved on their side delivery side up, but I don't want to tell you incorrectly so let it stand.
Best wishes and good luck
Colin
Thanks colin 1. I now know what to do. I'll let you know how I get on at the weekend.
PS. I am actually in Devon but was in Dorset. ( I pressed Dumfriesshire by mistake when registering. I think it's next to Dorset on the list!!!! ) :D
