I've never had to try it lying down (!), but you can do as long as you leave it to stand for at least 24 hours afterwards.
BTW, even more important than that is how you turn it off before moving it - you should turn down the thermostat, wait to make sure that the compressor isn't running, then switch off.
The reason for this is that the compressor will idle itself in a position wherein it will start again. If you pull the rug from under it then it's capable of stalling upon restart, thus burning out the motor. I've never proved that this is true, but have never wanted to either.
The compresor has a thermal cutout, you can switch it off at any time. All the t/stat does is disconnect power, its dosnt say 'hey compressor I about to switch off, so please park'.
Yes you can lay it down, depends on the construction as to what side you can lay it. Its all about the oil in the compressor draining. into the remaining pipwork/condensor/evaporator.
Ok the word speak, maybe should have been 'speak', cos we all know that 'things' dont have voice boxes.
Re what side to lay the fridge or freezer, its about what side the compressor has the 'closed off' charging pipe. This should be the low side when laying.
