Hi, I’d be really grateful for any advice to help with this problem. I’m losing hope with it..
I live in a typical 3 bed terraced house in London. My house has its own drain, not shared with the neighbours. It runs under the house and leads to the main sewer pipe in the street.
Here’s the problem, when the weather is warm and only when it hasn’t rained for a week or more (only during height of summer), my kitchen and downstairs WC smell really bad – cabbage / eggs. This smell can go all the way up the house. It disappears very quickly if the windows are left open for 5 minutes. Then you don’t smell it again all day and evening, until the next morning when you come downstairs. So it’s very specific – only during prolonged dry weather and only first thing in the morning / overnight.
In terms of remedies, I’ve had 3 thorough camera inspections and smoke tests. They found one improperly capped, disused junction running off the main pipe. And they found several fractures in the main pipe running under the house. There was also a bucan / interceptor trap that was removed to prevent any future problems. The pipe was then sleeved to cover the disused junction and to deal with multiple fractures in the pipe. The soil vent was checked – no blockages or problems.
All sinks and toilets have been tested for leaks using a bung in the main pipe and filling them up with water. No leaks detected.
2 weeks later, I’m still getting the foul smells.
Possible answers:
– cracked pipes leaking foul water into soil under house which is then drawn up when the weather’s hot? - ok, but new sleeve in pipe should have solved this by now.
-Dishwasher or washing machine sucking or blowing air out of traps on end of cycle? – ok but the smell comes whether appliances are used or not.
-Empty traps due to dry weather? – ok, but in that case the smell would be constant and not just first thing in the morning wouldn’t’ it?.
As you can see, I’ve thought about this and spent a small fortune on having people look at it and repair things and still nothing doing. Am I missing something?? Any ideas?
I have no idea what else to look for. Could it be a loose seal in the downstairs WC? If so, wouldn’t it have leaked when we tested it?
thanks for your help
Possible answers:
