Fitting a Laufen form bath with an aluminium frame to which the bath panel fixes then I will be tiling the panel with 457mm x 305mm travertine tiles. I was going to use 18mm wpb but it will be too thick when the tiles are fixed to it so I thought about 12mm wpb or aqua panel,but will these be strong enough any suggestions from you more experienced guys welcome.
