I
IainWatson
HI all,
Planning to tile walls of bathroom with travertine tiles. Two walls are standard stud walls with 9mm Plasterboard, one wall is 12mm plasterboard dabbed onto a sandwich of 4 more 12 mm boards and the final wall is 12mm board dabbed onto breeze block.
Supplier is suggesting that the tiles may be too heavy and simply pull off the boards from the "stud" walls and is trying to sell me Marmox Boards. Can anyone educate me as to how I work out the load bearing of each wall, and if it is indeed the case that the tiles are too heavy, if the suppliers suggested solution of Marmox Boards beneath the tiles is adequate/a good solution.
Any other solutions would be appreciated as this has come quite late in the whole refurb and has kind of stymied me a bit.
TVM,
Iain
TVM,
Iain
